dank an bruggi, der nachfolgende Info über unseren Akku gefunden hat:
ZE 50 battery of new generation Renault ZOE
- Total battery capacity: 54,66 kWh
- Usable battery capacity: 52 kWh (95 %)
- Battery weight: 326 kg
- Battery energy density: 168 Wh/kg
- Cells: 192 (96s2p)
- Chemistry: NCM 712
- Manufacturer: LG Chem
- TMS: active air cooling
Note: In the new generation Renault ZOE the ZE 40 battery is just a ZE 50 battery with capacity software-limited by the BMS (Battery Management System). It’s not the same ZE 40 battery that was available in the old generation.
